  • Connie DeCinko 931 posts 1160 karma points
    Nov 13, 2015 @ 15:24
    Connie DeCinko
    Publishing extremely slow
    Recent upgrade to Umbraco v.4.11.10. Site seems to perform just fine. However, publishing is a nightmare. It was working fine prior to the upgrade. Now, it takes several minutes for a simple page to publish. I've cleaned up old versions of content, checked for orphan content nodes and reindexed the Examine search collections.
    If I republish a folder with say 7 documents, I see Umbraco step through all 7 fairly quickly, however when it gets to the last document, the publish dialog stays open for 3 to 5 minutes, every time.
    What could be causing this?
  • Per Olsson 47 posts 307 karma points
    Nov 13, 2015 @ 15:45
    Per Olsson
    Try to delete the umbraco.config file and republish the site in case there is some problem with the XML cache.
    I never trust the Examine reindex tool so try to delete \App_Data\TEMP\ClientDependency manually instead and republish.
    Nicholas also have a nice guide here to disable Examine to rule out the issue: https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/72898-faster-way-to-publish-a-large-number-of-nodes#comment-233951
    As always, keep backups before you do something.
    Nov 13, 2015 @ 21:58
    Connie DeCinko
    Figured out the cause. web.config had the wrong SMTP address, the one from dev instead of prod. Corrected it and now all is good. Apparently Umbraco was having fits trying to send the email confirmations and choked on an incorrect SMTP server setting.
