Currently one of my content node is displaying an incorrect "Link to document"
My tree looks like this
- Content
- Home (/home) - Films (/home/films) - Features (/features)
As you can see films is displaying the wrong link to doc. I have republished, reindex, delete umbraco.config, delete content inside of "_systemUmbracoIndexDontDelete"
Remember that umbraco re-calculates the node's url when you publish it (or move it via the ui). So rather than a database hack, perhaps you could have simply opened the page for editing and then published it again? Or perhaps right-click the home page and republish it and all its children?
An idea for the next person having a similar issue :)
oh i spoke to soon. As doug saids usually "Link to document" issues are resolved by republishing. I've republished serveral times and am still having this issue
The content in bold is displaying the wrong address.
content - home - films - A ( /home/films/a ) // incorrect - B ( /films/b ) // correct
I've look in the umbracoNode table and the path seems correct (-1,-20,1044,1079,1259)
"-20" is the recycle bin. You should NEVER see that in a path or a "live" node in the content tree.
"-1" is the content tree so all "live" pages should have a -1 in them.
So, somehow the page was in the trash and moved back, maybe moved again, who knows how, and now it's confused.
There was a problem with restoring from the recycle bin a year or so ago in a specific version of umbraco (I think it was a v3 version but I don't recall off the top of my head).
- Content
- Home (/home)
How is this value generated?
There is a setting in umbraco settings.config for
HideTopLevelNodeFromPath
This should be true, and you should see this go agaw
Dan
yeah, i found that property in web.config
<add key="umbracoHideTopLevelNodeFromPath" value="true" />
I changed it to false and link to doc = "1079" which is the correct id.
I then changed it back to true and link to doc = "home/films" which is incorrect.
@dan : maybe your thinking of another property in "umbracosettings.config?"
I should prefix all this by saying that it was all working correctly until an editor accidentaly deleted home. Which is the cause of this mix up.
OK, i see what happened. Somehow the "path" field in the umbracoNode table got out of sync. Easy fix
UPDATE umbracoNode
SET path = '-1,1044,1079'
WHERE id = 1079
cheers,
doug.
content
- home
- films
AHA!
cheers,
doug.
wow, thanks doug. Made my day :)
All is working correctly. I suspect my app is throwing exceptions where i publish ( a job for monday )
I was able to fix this when some like the following. Obviously try this out a test installation first.
update umbracoNode set path = replace(path, '-1,-20,1044,1079,', '-1,1044,1079,') where path like '-1,-20,1044,1079,%'
