Im using sample menu from tutorials. It is created dynamibally by xslt macro- normal ul li. I also use css which has different class for actual menu element. Named for example current-element.
Problem is that I dont know how can I tell application which menu element is actual and chould have different css class so that it can be rendered in another way.
Using simple Asp.Net I could store that information in viewstate or just send it with post and so on.
remeber class in menu
thanks for help
Hi Snorlaks
If I understand your question correctly, you can find the current page (or current parents) with something like below
If it's only the "actual" current page you want, it would be something like
Hope this helps,
Dan
This is excactly what I was looking for.
Thank You very much for help.
By the way where did You learn how to use xslt in umbraco ?
No problem, glad you got it sorted.
For xslt in umbraco, I'd start with http://umbraco.org/documentation/books/xslt-basics and looking at the macros in http://our.umbraco.org/projects/business-website-starter-pack or http://our.umbraco.org/projects/creative-website-starter-(cws). ; You may learn to love it!
Dan
