I want to define my language files in visual studio rather than backoffice. Is this possible?
Hi!
I'd like to add language files to Config/lang/... for the site I'm buildning. So far, what I've read. You're suppose to add language "words" in umbraco backoffice, however. I would like to do it in lang files in visual studio.
What I concluded - No. Languages is stored in a dictionary and not XML if I got it right.
If you wan't to be able to transfer the dictionary between two or more databases like I did, I would recommend using uSync or any other project/tool to do that.
Hi!
Is this possible?
