  • Justin 1 post 31 karma points
    Feb 23, 2010 @ 06:03
    Justin
    Page visible to users only?
    Is there a way to make a content page visible to umbraco users only?  I see how you can use the "Public Access" option to set access for members but i'd like my admins to have access to specific pages without having to set them up as members as well...what am I missing here?
    Thanks!
  • Neil Campbell 58 posts 182 karma points
    Feb 23, 2010 @ 06:22
    Neil Campbell
    Hi Justin,
    No you cannot restrict access to front end pages by user, only members. My suggestion would be to create a member for each of the admin users and use Public Access, like you have said in your question.
    Neil
    Feb 23, 2010 @ 08:59
    Dirk De Grave
    As Neil points our correctly, users and members are different concepts, and therefore should not be mixed. I'd also go for the solution to create a user for each member that needs access to the page on the frontend.
    /Dirk
  • Seth Niemuth 275 posts 397 karma points
    Feb 23, 2010 @ 10:39
    Seth Niemuth
    Another option if you really want to restrict to just users, is to create a user control that checks if someone is logged in and if not, directs them to the login, and then add that to every page you want restricted.
