I would like to retrieve a list of all region under the regions folder.
in each event i use the multi tree picker.
I would like ask for advice what will be the XPath expression to be used in the multi tree picker in order to show a list of regions in the event ?
The regions that needed to be loaded are loaded on the same node (site1, site2...)
I would like to mention that if i use the "Node picker"option to select the node location, it works and i can see a list of regions in the event.
but if i use an XPath experssion i am getting an message "no strat node found"
XPath expression for uComponent Multi-Node Tree Picker
Hi to all,
I would like to mention that if i use the "Node picker"option to select the node location, it works and i can see a list of regions in the event. but if i use an XPath experssion i am getting an message "no strat node found"
Here is my Tree view:
thank you
Ori
