  • Warren Buckley 2106 posts 4836 karma points MVP 8x admin c-trib
    Feb 23, 2010 @ 17:44
    Warren Buckley
    Forgotton Password reset password not working - Umbraco 4.0.2.1
    Hiya Guys,
    Firstly like to appologise if this question has been asked before, if it has just point me in the right direction please.
    OK I have an umbraco 4.0.2.1 site and I am setting up a role based protection members area on the front end site and the <asp:login> controls and such work lovely.
    However the default <asp:PasswordRecovery> control I had no luck due to password being hashed. As when changing the membership provider settings in the web.config I get a YSOD saying
    Provider cannot retrieve hashed password
    OK then I thought I would create a custom .NET usercontrol to reset the password and send out an email.
    With the code below it is definately resetting the password with a new password, however when i try to then login, the new password sent out doesn't work. What am I doing wrong?
    Appreciate your input guys.
    Warren
    protected void btnRetrievePwd_Click(object sender, EventArgs e)
            string newPassword = string.Empty;
            //Get user based on their login name (when not logged in)
            MembershipUser user = Membership.GetUser(Username.Text, false);
            if (user == null)
                //User not found.......
                //Display message
                message.Text = "Username not found";
            else
                //Reset password
                newPassword = user.ResetPassword();
                //Need to email out the new password...
                string emailMessage = "Your new password is " + newPassword;
                //Send EMail
                sendEmail("mailer@telenorobjects.com", user.Email, "Reset password for Telenor Objects", emailMessage);
                //Display message
                message.Text = "Email sent with new password";
  • Tim 225 posts 690 karma points
    Feb 23, 2010 @ 17:48
    Tim
    Hi Warren,
    I think this may be related to the double hashing bug:
    http://umbraco.codeplex.com/WorkItem/View.aspx?WorkItemId=23320
    I submitted a patch for this, which has been accepted into version 4.1.
    I think the only workaround at this stage is to turn off password hashing.
    Although I might double check that.
    T
    Feb 23, 2010 @ 18:01
    Warren Buckley
    Cheers Tim :)
    Hmmm not sure if I can go bleeding edge with this client's site and go with the 4.1 beta 2 release.
    I'll run it past the guys at work and see what they have to say though.
    Warren
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Feb 23, 2010 @ 19:36
    Richard Soeteman
    Hi Warren,
    Had the same last week. Change the line
    to
     newPassword = Membership
    .GeneratePassword(6,2)
    bit hard coded but 6 is the length of your password and the 2 the amount of nonAlphanumeric digits
    More info on msdn
    Richard
    Feb 24, 2010 @ 10:14
    Warren Buckley
    Hiya Richard,
    Did this definately work for you?
    As I have just tried this and I am getting the new password sent in the email, but it still doesnt work with the login.
    <add name="UmbracoMembershipProvider" type="umbraco.providers.members.UmbracoMembershipProvider" enablePasswordRetrieval="false" enablePasswordReset="true" requiresQuestionAndAnswer="false" defaultMemberTypeAlias="Another Type" passwordFormat="Hashed" />
    Feb 24, 2010 @ 12:15
    Richard Soeteman
    Hi Warren,
    Was watching speedskating yesterday so I made a mistake. You need to assign the new password to the member also. I am using the umbraco member objects for this. I know this is not the prefered approach but when using the default member objects you can set the password . I've used the code below:
    string newPassword = Membership.GeneratePassword(6, 2);
    Member member = Member.GetMemberFromEmail(someemail@test.com);
    member.Password = newPassword;
    member.Save();
    Hope it works for you,
    Richard
  • Ian Smedley 97 posts 192 karma points
    Mar 25, 2010 @ 14:51
    Ian Smedley
    3
    I've found this quite interesting, I originally (wrongly) assumed that to change a member's password, you would set set the password property, and it would work out the hashing or encryption, such as:
    m.ChangePassword("password");
    What I actually found was this just wrote the value straight into the database, and thus the user could not log on after changing the password, so, I found that using the helper functions, you could hash the password manually, this applies for members changing their password, creating new accounts, or an administrator having the ability to set a members password (outside of Umbraco's admin suite)
    In this example, 1 is the fictional member ID!
    m = new Member(1);
     MemberShipHelper mh = new MemberShipHelper();
     m.ChangePassword(mh.EncodePassword(txtPassword.Text, MembershipPasswordFormat.Hashed));
    Mar 26, 2010 @ 09:53
    Warren Buckley
    Ian i totally forgot about this post, but this looks like a good solution to the problem.
    Warren
  • Sascha Wolter 615 posts 1101 karma points
    Aug 18, 2010 @ 12:37
    Sascha Wolter
    Works using 4.0.4.2 as well.
    Thanks for that Ian! :)
  • Tom W 39 posts 96 karma points
    Aug 30, 2011 @ 16:19
    Tom W
     string newpassword = GeneratePassword();
                member.Password = newpassword;
                member.Save();
    If you wish to set the password directly, without using the MembershipProvider, this works and correctly hashed the password (GeneratePassword just does a Guid.NewGuid().ToString().Replace("-", "").Substring(0, 6) - but this could be anything.)
