I was wondering if it is possible to specify a nodeid in an external css file - I have tried the following but I'm guessing it doesn't work as ti doesn't know which doctype to use?
Most people tend to keep css related images (those that are used for layouting) in a /images folder, not stored on doc level or in media section.
If you still want it to be dynamic, put this snippet in your template (using inline styling), so it gets *replaced* by the document's value at runtime.
Thanks, I do usually keep my css images in a media section but for 3 particular banners on my website, I need them to be backgrounds and they are likely to change regularly hence my needing to specify a nodeid.
Could you possibly post the snippet that you refer to above?
Specify a node id in external css
Rachel
hi Rachel,
/Dirk
Many thanks,
Rachel
Rachel,
Just put your code in template using syntax:
Hope this helps.
Regards,
/Dirk
Ah, sorry, I see what you mean now! Thanks very much.
Rachel
