  • Andrew Blackmore 84 posts 127 karma points
    Feb 24, 2010 @ 22:51
    Andrew Blackmore
    Making contact log info go away
    Hi All,
    When I log into Umbraco, it displays a warning about there being no contact us logs and no email to a friend logs. I don't have either of those currently implemented on this solution and would like not to see it. I have no idea how to get rid of these however. Any ideas?
    thanks
  • Douglas Robar 3570 posts 4711 karma points MVP ∞ admin c-trib
    Feb 24, 2010 @ 23:09
    Douglas Robar
    These are part of the CWS2 package. To deactivate them, edit the /config/dashboard.config file. Comment out the section for these items. For example:
    <section alias="MyDashboardSection">
    <areas>
    <area>default</area>
    <area>content</area>
    </areas>
    <tab caption="Contact Logs">
    <control>/usercontrols/dashboards/ContactForm_logs.ascx</control>
    </tab>
    <tab caption="Email a Friend Logs">
    <control>/usercontrols/dashboards/EmailAFriendForm_logs.ascx</control>
    </tab>
    </section>
    cheers,
    doug.
  • Peter Dijksterhuis 1442 posts 1722 karma points
    Feb 24, 2010 @ 23:10
    Peter Dijksterhuis
    Hi Andrew,
    open up /config/Dashboard.config
    Remove the 2 tabs (tab caption=Contact log and tab caption=Email a friend Logs) and I think your errors will disappear :)
    HTH,
    Peter
    Feb 25, 2010 @ 18:16
    Andrew Blackmore
    Hi Guys,
    Thanks for the speedy response. Worked perfectly. Had to give the solution points to Douglas cause he just barely beat your answer in Peter. Sorry
    Feb 25, 2010 @ 18:39
    Peter Dijksterhuis
    Haha no problem. Douglas gave a more detailed answer anyway :)
