  • Disham Parikh 5 posts 75 karma points
    Feb 04, 2016 @ 07:44
    Disham Parikh
    Examine not able to search the word "IT"
    I came across some weird issue, I am using Examine to search my content. My contents are having three "dropdownList Multiple" property countrylist, industrylist and technologylist. among which industrylist dropdown have value "IT", Examine search working great for all the word search except the word "IT", i tried to use wildcard search as well e.g.(industrylist:i*), but examine showing me "No result found".
    Please note that, i have two contents which industrylist's prevalue is "IT" and still is showing me "No result found".
    Possible solution could be, i can search by prevalue's ID, but i don't know how can i search by prevalue ID using examine.
    Please let me know possible solution.
    Regards,
    Disham
    Feb 04, 2016 @ 07:55
    Ismail Mayat
    Disham,
    I suspect you are using external index which uses standard analyser which will strip stopwords namely common words which are just noise e.g it, and the etc.
    If you do a search on the forums I recall Barry Fogarty worked around it as he had very similar issue to you unfortunately on a train at the moment.
    Regards
    Ismail
    Feb 04, 2016 @ 08:41
    Disham Parikh
    Thanks Ismail, your hint worked for me.
    following post of Barry Fogarty helped me to solve my issue.
    https://our.umbraco.org/forum/developers/extending-umbraco/25600-Examine-case-insensitive-keyword-search
    Creating custom analyzer solved my issue.
    Many thanks.
