Apologies if this has already been posted; I don't know the proper name for the triangles that I'm asking about :)
In Umbraco 7.3 and 7.4, when creating a link from the RTE you get a panel on the right-hand side of the screen. At the bottom of the options is an item called "Home". This is actually an expandable sitemap but that's not obvious unless you move the pointer over it, which causes a triangle to appear to the left (showing that it can expand).
Is there any way to make the triangle always show up, or some other way of making this feature more "discoverable"? I've had multiple editors ask how to link to other pages; a label simply saying "Home" isn't very user-friendly so I'd love to improve this if I can. Is there a setting somewhere?
Perhaps it's a good idea to raise this issue on the issue tracker with a UX label or feature request label to make people aware that it can be an issue and something that might need some TLC in the core.
I would use the browser's DOM inspector and figure out the class and html structure and then create a CSS rule to ensure that the triangle icon is always visible.
Always show "triangles" when creating links
Hi Craig
You should be able to overwrite Umbraco's styling by including your own stylesheet like Matt writes about here in the section "Custom CSS" http://24days.in/umbraco/2015/umbraco-7-back-office-tweaks/
Hope this makes sense :)
Thanks; I had no idea that you could override the CSS in the backoffice.
For anyone else that wants to accomplish the same thing, this is all you need:
