One of my properties has gone missing on the generic property tab after the upgrade to 7.4.1.
On the document type I can see the property but I can't view it on the node. I tried shifting the property to another tab but it still will not appear.
What version did you upgrade from? And did you do it using nuget or was it done manually?
I'm not sure but I suspect this might be a bug in v7.4.x since it's no longer possible to place your own properties on the generic properties tab. So perhaps that's the reason why it's failing when upgrading.
Not sure how the upgrade script could/should handle this but perhaps it's worth filing an issue at the issue tracker about it http://issues.umbraco.org/
Generic property gone missing after upgrade 7.4.1
Kind regards Nick
Hi Nick
Hi Jan
It was through nuget and I upgraded from 7.3.4 - 7.4.1
Everything seem to go smoothly but thanks I will log a ticket
