  • Rachel Skuse 88 posts 118 karma points
    Mar 03, 2010 @ 10:34
    Rachel Skuse
    Page is redirecting to home page (without redirection!)
    I have a bit of a strange problem where by a published page is being redirected to my home page but I haven't got any redirection on it?!
    Has anyone come across this before or enlighten me on what might be happening?!
    Rachel
    Mar 03, 2010 @ 10:39
    Dirk De Grave
    Rachel,
    Can you post outcome of the url with querystring ?umbdebugshowtrace=true appended?
    /Dirk
    Mar 03, 2010 @ 11:55
    Rachel Skuse
    Hi Dirk,
    Here's the url
    http://www.server1518.co.uk/home.aspx?umbDebugShowTrace=true
    (I thought that would be easier than posting the outcome!)
    The page I am trying to access is http://www.server1518.co.uk/essential-living/default.aspx
    Rachel
    Mar 03, 2010 @ 12:03
    Dirk De Grave
    Rachel,
    Guess that's because you're page is called "default", try renaming it to something else and see if that works!
    /Dirk
    Mar 03, 2010 @ 13:42
    Rachel Skuse
    Doh! I've renamed and it's fine now - thanks! I just assumed that as the page was within a directory, it was acceptable to call it 'default' - obviously not!!
    Rachel
