  • Fergus Davidson 309 posts 588 karma points
    Mar 03, 2010 @ 12:07
    Fergus Davidson
    BUG?? copying document type duplicates parents properties
    hi
    not sure if this is a bug or a feature, or whether i am just doing it wrong.
    when i copy a document type, i was expecting it to be the same, with the same properties and tabs. what i am getting, though, is a new document which has the properties and tabs of the copied document type AND its parent.
    ie i have, on my default document type, meta information, which the majority of pages will need, so i have just included them there. i then have a standard page document which has page title, body text etc.
    when i copy the standard page, i have a new document type with both tabs and sets of properties.
    obviously i can delete them, but i wonder now whether my newbie-brain is not structuring things properly, whether i should in fact not inherit the properties.
    can someone offer a bit of insight here?
    thanks
    Mar 03, 2010 @ 12:56
    Dirk De Grave
    Can you report this on Codeplex? Make sure to add version and environment info for the core team to repro!
    TIA,
    /Dirk
