  • chris 4 posts 24 karma points
    Mar 03, 2010 @ 18:46
    chris
    insert FLV files
    I am a beginner at Umbraco, can someone please help me get flash flvs in umbraco
  • Ranjit J. Vaity 66 posts 109 karma points
    Mar 03, 2010 @ 19:01
    Ranjit J. Vaity
    Hi Chris,
    You might want to try these 2 links below:
    http://www.nibble.be/?p=28
    http://www.nibble.be/?page_id=4#nibblefx
    Regards,
    Ranjit J. Vaity
    Mar 03, 2010 @ 19:18
    Hi Chris
    You could also try to play around with some of the packages for video inserting, which are listed here http://our.umbraco.org/projects/tag/video#projectList
    I hope this helps.
    Mar 03, 2010 @ 21:47
    dandrayne
    <plug>This package should work for you!</plug>  The other projects in http://our.umbraco.org/projects/tag/video seem to be for embedding external content, not for embedding your own flvs from the media library.  I should probably update that package at some point...
    Dan
    Mar 05, 2010 @ 21:06
    chris
    Thanks Dan for the recommendation.
    but im not totally clear on how to install it into umbraco, what steps do i take to install it?
    Mar 05, 2010 @ 21:29
    Hi Chris
    To install the package you need to go to do the following
    1) Download the package to your computer
    2) Go to the developer section in Umbraco and select "Packages"
    3) Choose to install "Local package"
    4) Browse to the package you have just saved on your computer and follow the installation steps.
    Then you should be ready to go.
    Hope this helps you
  • Anders Burla 2560 posts 8256 karma points
    Mar 05, 2010 @ 21:47
    Anders Burla
    I created this package exatly yo make it easy to insert both flv files from your media library or external url
    http://our.umbraco.org/projects/insert-flash
    Mar 05, 2010 @ 21:52
    chris
    i hate to sound like I have no idea what im doing but this flow player, isnt it suppose to have a umb file somewhere so i can install the package
    Mar 05, 2010 @ 21:59
    chris
    I actually got it installed thanks
