My Macro button is missing from the RTE I am using Umbraco 4.7.1 which was upgraded from 4.7.0. I am using Contour 1.1.11 the Macro button is there under Data Types - Rich Text Editor. I've checked it and un checked it. The other buttons disappear and re-appear but not the Macro button.
Macro icon disappeared in RTE
Hi All,
This is a wierd one, I installed Contour and since then my Macro icon in the RTE has disappeared so cant add any Macro or Form to my content.
But I can still add them via the templates, which obviously I dont want content editors to do, anyone have any ideas where to look?
Tom
Try looking at your Richtext DataType, and see if the checkbox has been unchecked somehow.
I've looked and there doesn't even seem to be a checkbox for the Macro items in the datatype.
Now I'm confused!!
