The sortOrder is not working only with some of the nodes. Not with every of them. The nodes failing don´t get updated neither in database nor Umbraco.config I tried changing sortOrder value in database manually and the order changes correctly, but later I try through CMS and it´s still failing.
Sorting nodes not working
Umbraco version 4.0.2.1.
Sorting nodes does not work.
I right click my node which childs i want to sort.
I get the modal and i see the child nodes having sortorder from 0 - 10.
But the changes im making doesnt follow through!
Any ideas what could be the problem ?
Tried using FireBug to see whats going on and it tells me in the POST:
{"ParentId":1358,"SortOrder":"2563,5610,3106,3119,3263,2835,2616,2537,2539,2322,2312,"}And in the RESPONSE:
Tried Reloading nodes on parent node and on the content node but it does nothing.
If i look in the database: umbracoNode table i can see the sortorder is the same as before so no change there.
Tried moving 5610 to sortorder 0 and that worked. However now 2563 and 5610 has sortorder 0
Cant move them back in right order - have to change sortorder in database.
This is so strange!
Ok sorting works on all other nodes but this one!
Really need some help here guys ? :(
Did you figure this out? It appears to be a bug when content has a "Remove at" date.
Same problem here. Really weird.
I´m using Umbraco 4.7
Does your /App_Data/Umbraco.config file get updated after you sort documents in the back end?
Rich
I guess some data is corrupted in any way.
Any ideas?
