  • Kris Dyson 54 posts 79 karma points
    Mar 11, 2010 @ 17:33
    Kris Dyson
    Merge node sets
    Hi there, I want to merge to rss feed resultsets, then order them... is this possible with xslt?
        <xsl:variable name="rss1" select="umbraco.library:GetXmlDocumentByUrl('http://newsrss.bbc.co.uk/rss/newsonline_uk_edition/front_page/rss.xml')" />
    <xsl:variable name="rss2" select="umbraco.library:GetXmlDocumentByUrl('http://newsrss.bbc.co.uk/rss/newsonline_uk_edition/uk_politics/rss.xml')" />
    Ideally I'd like to merge the results, order them by date and then output the first 30 items,
    It's the merging bit that I'm struggling with - any suggestions?
    thanks
    Kris
  • Douglas Robar 3570 posts 4711 karma points MVP ∞ admin c-trib
    Mar 11, 2010 @ 17:46
    Douglas Robar
    Off the top of my head (which means I haven't tried this), can you create a union of the feeds with this?
    <xsl:variable name="feeds" select="umbraco.library:GetXmlDocumentByUrl('someUrl1') | umbraco.library:GetXmlDocumentByUrl('someUrl2')" />
    Then you'd have a single variable of everything that you could <xsl:for-each> and <xsl:sort>.
    cheers,
    doug.
    Mar 11, 2010 @ 18:21
    Douglas Robar
    Thinking another minute about this... you might need to add a wrapping xml element around the whole thing to avoid having two root elements (one from each rss feed). To do that you should be able to do something like:
    <xsl:variable name="feeds" select="concat('&lt;feeds>', umbraco.library:GetXmlDocumentByUrl() | umbraco.library:GetXmlDocumentByUrl(), '&lt;/feeds>')" />
    Hope these little snippets of ideas help out.
    cheers,
    doug
    Kris Dyson
    Hi Doug, thanks for this. However, the feeds are not static, they come from a list of rss feeds that the user has selected.
    I wonder if it's possible to create an xml doc in XSLT, importing nodes from GetXmlDocumentByUrl and storing the result in a variable... then it would be possible to do a xsl:sort
    k
    Mar 11, 2010 @ 18:26
    Kris Dyson
    do you know if it's possible to store inline xml in a variable?
        <xsl:variable name="rssFeeds">
          <container>
            <hello></hello>
          </container>
        </xsl:variable>
    I cannot do this at the moment, i get 'To use a result tree fragment in a path expression, first convert it to a node-set using the msxsl:node-set() function. at System.Xml.Xsl.Runtime.XsltConvert.EnsureNodeSet...'
    Mar 11, 2010 @ 18:29
    Kris Dyson
    oh it's OK, that's my fault that didn't work!
    Mar 11, 2010 @ 18:31
    Douglas Robar
    Also might need to use the msxsl:node-set() around the whole thing.
    cheers,
    doug.
    Mar 11, 2010 @ 18:34
    Douglas Robar
    It will get a bit more tricky to do it all in xslt but it isn't impossible by any means.
    Catch me up on what you've got so far and if there's anything left to resolve. I (or any of a large number of other folks in the community) are happy to help.
    cheers,
    doug.
    Mar 11, 2010 @ 18:44
    Kris Dyson
    Hi Doug, think I have worked it out...
          <container>
            <xsl:copy-of select="umbraco.library:GetXmlDocumentByUrl($url)"/>
            <xsl:copy-of select="umbraco.library:GetXmlDocumentByUrl($url2)"/>
            <xsl:copy-of select="umbraco.library:GetXmlDocumentByUrl($url3)"/>
          </container>
        </xsl:variable>
       <xsl:for-each select="msxsl:node-set($rssFeeds)/container/rss/channel/item">
          <xsl:sort select="pubDate" order="descending"/>
          <xsl:if test="position() &lt;= 30">
            <h1>
              <a>
                <xsl:attribute name="href">
                  <xsl:value-of select="link/text()"/>
                </xsl:attribute>
                <xsl:value-of select="title/text()"/>
              </a>
            </h1>
            <p>
              <xsl:value-of select="description/text()" />
            </p>
          </xsl:if>
        </xsl:for-each>
    This seems to work OK, it was that I didn't use node-set in the correct place.
    We have a system wide set of RSS feeds, and users select the ones they want.  The RSS feeds are Nodes under Content like anything else and the when the user selects one to subscribe to, the content node id is set into a CSV property of the member profile (just a CSV list of node ids of rss feeds)
    So for my next trick, I'm going to attempt to loop through the subscribed rss feeds' node ids in the member type and then pull the url from the content node, then use library:GetXmlDocumentByUrl to get the xml and import it
    Hope there's some way to deal with CSV in XSLT :-)
    Kris
    Mar 11, 2010 @ 18:48
