  • Alex 35 posts 55 karma points
    Mar 15, 2010 @ 01:23
    Alex
    Admin UI localization
    Is it possible at all? For example, can I switch the admin area UI to German?
  • Shannon Deminick 1530 posts 5278 karma points MVP 4x
    Mar 15, 2010 @ 04:57
    Shannon Deminick
    Yes, you can set the admin user's localized language settings for the admin UI when editing an admin user.
    There's some minor bugs with this in pre 4.1 but should all be fixed in the 4.1 release.
    Mar 15, 2010 @ 06:22
    Alex
    Wow! That's easy :) How difficult will it be to add a new (not yet supported) language?
    Mar 15, 2010 @ 11:42
    Shannon Deminick
    Somewhere on the Umbraco site they had the ability to submit new language packs and update existing ones. I'm sure someone has more info on where this is (or if it is still around).
    There's XML files in the /umbraco/config/lang folder. You'd need to create a new one of those and translate everything!
  • Frank v Braak 10 posts 28 karma points
    Mar 20, 2011 @ 00:23
    Frank v Braak
    Is it possible to translate f.e. uCommerce too? This part of the admin is now still in English. I would love to have it in Dutch. (I can make the translation myself, but I dont know WHAT to translate :P)
    Can someone pass me the keywords to translate?
