Hiya,
Is it true that you can't delete single files from the recycle bin? "Right-click > delete" doesn't have any effect. A client wants to delete some files from the bin but not all of them...
Anyone with similar problems?
Just checked it... it seems not possible (tried it on v403) altho context menu for delete is available. May be best to report this issue on Codeplex!
TIA,
/Dirk
Exactly... I'll post it. Just wanted some feedback before adding the issue. :)
Issue reported on Codeplex:
http://umbraco.codeplex.com/WorkItem/View.aspx?WorkItemId=26476
Deleting single nodes from recycle bin?
Hiya,
TIA,
/Dirk
