I installed Umbraco and tried to do something really simple. Created a Master template and a document type called Homepage (with one property "name"). This document type has the respective template which has the MasterFilePage set to the Master template I created.. The Homepage template has only <h3>Homepage</h3>.
But when I try to preview this content I get the following page:
The link in the address bar is: localhost:51534/1051.aspx?umbVersion=9f3a9538-1f04-432c-aebd-340405b4af61 (but even if i open the localhost:51534/homepage.aspx address I get the same thing).. So, what's this and how can I solve it?
Very strange that you'd get a trace without requesting it.
I suspect your masterpage template is not referencing the underlying umbraco template properly. Can you paste in the code of the template associated with your homepage document type?
<asp:Content ID="Content1" ContentPlaceHolderID="ContentPlaceHolderDefault" runat="server"> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <HTML> <HEAD> <TITLE>My first HTML document</TITLE> </HEAD> <BODY> <h1>Master Header</h1> <br /><br />
It doesn't, I keep getting the same page every time I try to preview the page either from Umbraco or from Visual Studio.. I've done another test project in Umbraco and that time everything went smoothly, I don't understand why this happens now.
Can't preview content
http://img411.imageshack.us/img411/5839/umbracoshot.jpg
Thanks in advance
cheers,
doug.
Hey, thanks for the reply. Here's the code I have..
Master Template:
<%@ Master Language="C#" MasterPageFile="/umbraco/masterpages/default.master" AutoEventWireup="true" %>
<HTML>
<HEAD>
</HEAD>
<BODY>
<br /><br />
<asp:PlaceHolder ID="mainBodyPlaceHolder" runat="server" />
<br /><br />
<h1>Master Footer</h1>
</BODY>
</HTML>
</asp:Content>
And in the Homepage template, just this:
<%@ Master Language="C#" MasterPageFile="/masterpages/TestMasterPage.master" AutoEventWireup="true" %>
<asp:Content ContentPlaceHolderID="mainBodyPlaceHolder" runat="server">
<h3>HOMEPAGE MAIN BODY</h3>
</asp:Content>
Thanks!
In your Master template, replace this line:
with this line:
Does that solve it?
cheers,
doug.
