  • Peter Bradsted Bodenhoff 27 posts 47 karma points
    Mar 18, 2010 @ 11:35
    Strange behaviour .... richtext-elements in XLST
    I am a bit confused....
    In my DocumentType I have defined two richtext-elements. One for each column in a table. When I call the elements in the Template they present nicely - but when i call "Column1" in my XSLT they return both "Column1" AND "Column2"...
    Is there some kind of explanation??
    TEMPLATE
    <table>
    <tr>
    <td width="270" valign="top">
    <umbraco:Item field="column1" runat="server"></umbraco:Item>
    </td>
    <td width="10"></td>
    <umbraco:Item field="column2" runat="server"></umbraco:Item>
    </td>
    </tr>
    </table>
    XLST
    <xsl:if test="$template = 'table'">
    <table>
    <tr>
    <xsl:value-of select="umbraco.library:GetXmlNodeById(umbraco.library:RequestQueryString('ID'))/self::node [data [@alias='column1']]" disable-output-escaping="yes"/>
    </td>
    <xsl:value-of select="umbraco.library:GetXmlNodeById(umbraco.library:RequestQueryString('ID'))/self::node [data [@alias='column2']]" disable-output-escaping="yes"/>
    </td>
    </tr>
    </table>
    </xsl:if>
