I am trying to create a table using TinyMCE - I put in the number of rows I need/number of columns I need - I fill out all the necessary information but once I click on insert - it goes right back to the TinyMCE Table info but everything goes back to default which is 2 rows 2 columns and no table gets inserted. Any idea why this might be happening?
If so, in the validsettings part of /config/tinymceconfig.config I think -td is set by default, meaning that it will remove empty cells. Remove the minus and try again.
Okay Im an idiot - Im using 4.0.3 - this is what I get for typing too fast. :) Okay will give that a try when I get home from work. Thanks for the advice! Thanks a million!
Issues using Tables with TinyMCE
Im using the latest Umbraco package - 4.01
Thanks!
Were the table cells empty?
Dan
p.s. 4.0.3 is the latest version!
No worries, remember to "touch" the web config after changes to tinymce settings just to be sure your changes have taken effect
Dan
Works like a charm, cheers guys :)
