Hi this is probably a very simple question and probably so easy i cant find the answer on the forums. This is my first umbraco site build. I'm trying to create a document type that has a drop down list with four options but when i go to generic properties on document types, add a drop-down property i dont know then how to add options to the drop down?
You add the options in the Developer < Data Types < Dropdown. You will probably want to create a new data type for your specific dropdown with a relevant name.
DropDowns in Document Type
Regards
Phil
Thanks!
