Is there anyway to diplay the umbracoBytes value as MB instead of KB?
Just divide it by 1024, and round to the number of decimals you need.
here is a script i use...
<a href="{$docFile}" title="{$docName}" target="_blank"><xsl:value-of select="$docName"/></a> [ File Size: <xsl:value-of select="format-number(data[@alias='umbracoBytes'] div 1024,'#,###')"/>]
Here is the xslt extension helper we are using to print out the bytes nicely, in GB, MB, KB or bytes depending on the size
public static string GetReadableFileSizeViaBytes(long Bytes){ if (Bytes >= 1073741824) { Decimal size = Decimal.Divide(Bytes, 1073741824); return String.Format("{0:##.##} GB", size); } else if (Bytes >= 1048576) { Decimal size = Decimal.Divide(Bytes, 1048576); return String.Format("{0:##.#} MB", size); } else if (Bytes >= 1024) { Decimal size = Decimal.Divide(Bytes, 1024); return String.Format("{0:##} KB", size); } else if (Bytes > 0 & Bytes < 1024) { Decimal size = Bytes; return String.Format("{0:##.##} Bytes", size); } else { return "0 Bytes"; }}
This is the above as XSLT ;) Laurie
<xsl:variable name="size" select="data [@alias = 'umbracoBytes']" /> <xsl:variable name="sizeAndSuffix"> <xsl:choose> <xsl:when test="$size >= 1073741824"> <xsl:value-of select="format-number($size div 1073741824,'#,###')"/> <xsl:text>GB</xsl:text> </xsl:when> <xsl:when test="$size >= 1048576"> <xsl:value-of select="format-number($size div 1048576,'#,###')"/> <xsl:text>MB</xsl:text> </xsl:when> <xsl:when test="$size >= 1024"> <xsl:value-of select="format-number($size div 1024,'#,###')"/> <xsl:text>KB</xsl:text> </xsl:when> <xsl:when test="$size > 0 and $size < 1024"> <xsl:value-of select="format-number($size div 0,'#,###')"/> <xsl:text> Bytes</xsl:text> </xsl:when> <xsl:otherwise> <xsl:text>0 Bytes</xsl:text> </xsl:otherwise> </xsl:choose> </xsl:variable>
Display umbracoBytes as MB instead of KB
