  • Randy 2 posts 23 karma points
    Mar 23, 2010 @ 19:40
    Randy
    Stylesheets not showing in Settings
    When I go to Settings > Stylesheets and create a new stylesheet, I am able to create it successfully and see it physically on the server in the css directory. However, it never actually shows up in the Stylesheets node. If I open or refresh the node, I briefly get the 'One moment please...' node, and then it disappears, showing the node as empty. Is there something special I need to do to have existing stylesheets show up here?
    Mar 23, 2010 @ 21:15
    Randy
    For anyone else with this problem, a user created a stylesheet and included the ".css" in the name, so the physical file name ended up being "style.css.css". Umbraco couldn't handle this at all for some reason and wouldn't show anything in the list. Once the physical file was changed to "style.css" the list reappeared.
    Mar 23, 2010 @ 21:35
    Dirk De Grave
    Good feedback! May have been reported on Codeplex before, but would be gr8 if you could check and vote if it's there, otherwise create a work item for this.
    TIA,
    /Dirk
