    Mar 23, 2010 @ 23:35
    Task with id: '1101' not found - Questions about the "Send To Translation" function...
    Hi guys
    I'm currently playing around with the "Send To Translation" function.
    When I'm trying to login using the provided URL that looks like this: http://example.com/umbraco/translation/details.aspx?id=1101
    I get the following ASP.NET error and I'm wondering what I need to do to fix it. Also I would like to know where the text in the generated e-mail notification can be changed?
    Exception Details: System.ArgumentException: Task with id: '1101' not found
    Source Error:
    Stack Trace:
    [ArgumentException: Task with id: '1101' not found]
       umbraco.cms.businesslogic.task.Task..ctor(Int32 TaskId) +483
       umbraco.presentation.umbraco.translation.details.Page_Load(Object sender, EventArgs e) +99
       System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
       System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
       System.Web.UI.Control.OnLoad(EventArgs e) +99
       umbraco.BasePages.BasePage.OnLoad(EventArgs e) +15
       System.Web.UI.Control.LoadRecursive() +50
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
    Version Information: Microsoft .NET Framework Version:2.0.50727.3603; ASP.NET Version:2.0.50727.3601
    Thanks in advance
    Mar 24, 2010 @ 08:30
    Dirk De Grave
    Hi Jan,
    Issue's been reported before as per my article.
    /Dirk
    Mar 24, 2010 @ 09:50
    Hi Dirk
    Cool guide you have written. Just bookmarked it for future reference.
    Do you know where the text in the e-mail can be changed?
    Mar 24, 2010 @ 09:58
    Dirk De Grave
    Yup, sure I can... but so can you... en.xml in umbraco\config\lang folder.
    /Dirk
