Guys,
I have just logged in as a translator in umbraco 4.0.3 gone to translate section and clicked a task assigned to me and i get the following error:
[ArgumentException: Column 'Name' does not belong to table .] System.Data.DataRow.GetDataColumn(String columnName) +1773557 System.Data.DataRow.set_Item(String columnName, Object value) +12 umbraco.presentation.umbraco.translation.details.Page_Load(Object sender, EventArgs e) +1404 System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14 System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35 System.Web.UI.Control.OnLoad(EventArgs e) +99 umbraco.BasePages.BasePage.OnLoad(EventArgs e) +15 System.Web.UI.Control.LoadRecursive() +50 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Anyone seen this before?
Regards
Ismail
Just to update,
When the user translator-fr has language set to english-uk in backend then you dont get error. Its only when users language is set to french so looks like for the translate section something with ui translation is going wrong.
Here you go: Codeplex work item
/Dirk
Error in translate section
Guys,
Regards
Ismail
Just to update,
Regards
Ismail
/Dirk
