  • Rachel Skuse 88 posts 118 karma points
    Mar 24, 2010 @ 12:44
    Rachel Skuse
    Importing a Document Type
    I assumed that by importing a docType with the same alias as an existing docType it would just override it? This doesn't seem to be the case. Am I doing something wrong or is it not possible to do?
    Rachel
    Mar 24, 2010 @ 13:07
    Hi Rachel
    I don't think that it's possible to override an exiting document type.
    But I think that the two types may have been merged so that the properties from either the imported or the old one is moved to the "generic properties" pane...
    Mar 24, 2010 @ 13:11
    Rachel Skuse
    I actually just deleted some nodes, so I was hoping that it would remove them on the new import but no such luck but thanks for your advice.
    Rachel
