  • Maarten Boer 61 posts 82 karma points
    Mar 25, 2010 @ 22:12
    Maarten Boer
    TinyMCE problem with styles, fonts and bold
    I'm using a div which is controled by a css file.
    css:
    #content {
           font:Calibri, Verdana, sans-serif;
           etc.
    I have added styles h1 to h6 behind the richtext editor and in these styles i only set the fontsize.
    Now when i edit the content of my page i can select text and click on BOLD .....and it works perfect.
    But once i choose the style h4 (16px) and select the text again, i can't use BOLD anymore. Italic works fine in both cases.
    Any Idea ??????
    Mar 25, 2010 @ 22:20
    Kim Andersen
    Hi maarten
    If you haven't changed anything in your CSS-file rearding your headings, they are as default bold. This means that when you put some text in a Hx-tag, this text will, by default, be assigned with a bolder font than regular text.
    Could this have something to do with it?
    /Kim A
