  • Christian Tarrild 23 posts 43 karma points
    Mar 26, 2010 @ 10:39
    Christian Tarrild
    Members do not save in Chrome
    I am running Umbraco v 4.0.3 (Assembly version: 1.0.3674.221). When i update a member property through the user interface and press the save button the changes are not saved when using Chrome 4.1.249.1042 and the "Member saved" popup does not show. I have reproduced the error in another umbraco installation using umbraco v 4.0.2.1 (Assembly version: 1.0.3441.17657).
    The problem only exists when saving members. Every thing else saves beautifully.
    If I update the member property in IE8 there is no problem.
    Regards
    Tarrild
    Mar 26, 2010 @ 10:52
    Dirk De Grave
    Christian,
    Probably because of the password fields... it's a known issue, but more of a browser issue because Chrome can store username/password combinations, but doesn't fill in the 'confirm password' field. Simple workaround is to expand the password part and retype passwords.
    /Dirk
    Dirk De Grave
    Also moved it to this category as it wasn't exactly a our.forum bug
    /Dirk
  • Nikolas van Etten 202 posts 162 karma points
    Mar 26, 2010 @ 11:09
    Nikolas van Etten
    Dirk,
    The workaround is ok, but not ideal as I for sure don't keep passwords for all editors.
    Do you know if there's anything on codeplex for this (I'd like to vote it up)?
    Nik
  • Fredrik 41 posts 161 karma points
    Mar 26, 2010 @ 11:28
    Fredrik
    Hello!
    Keep in mind that there are some other issues with chrome aswell. I could not insert tables or adjust width/height of pictures in the RTE.
    Regards,
    Fredrik
    Mar 26, 2010 @ 11:41
    Christian Tarrild
    Thank you for our quick replies. Sorry for misplacing my question. It was indeed Chrome filling out the change password field for the member without filling out the confimation.
