  • Daniel Horn 319 posts 344 karma points
    Mar 27, 2010 @ 11:32
    Daniel Horn
    Comments on nodes
    Ive tried to get http://our.umbraco.org/projects/ucomment/using-ucomment/8032-Cant-get-it-to-work to work, but it won't
    so is there a simple way to add comments to nodes?
    If not, can someone give me some pointers on how to get going building something? :)
    Mar 27, 2010 @ 13:09
    Hi Daniel
    It should be possible to achieve the "AutoForm", which is a part of the utilities package available in the package repository. You can also use doc2form, but I can't remember where to get it from at the moment.
    Mar 27, 2010 @ 14:48
    Daniel Horn
    Ah, yes - haven't used doc2form before, but I can see how i could do it with that package.
    Will try to set it up with both packages to see what's working best, thanks for the pointers :)
    Mar 27, 2010 @ 14:49
    Daniel Horn
    And here's a doc2form guide for anyone else interested:
    http://www.blogfodder.co.uk/post/How-To-Get-doc2form-For-Umbraco.aspx
    Thanks to Lee :-)
