  • Jonas 10 posts 30 karma points
    Mar 30, 2010 @ 10:48
    Jonas
    Dropdown etc for MemberTypes
    I have made some MemberTypes for my Umbraco solution and really want to have drop downs for members with some options of my choice. Can anyone point my in the right direction of how this works? Whenever I create a drop down property, I dont know how to fill it with options.
    Mar 30, 2010 @ 11:44
    Kim Andersen
    Hi Jonas
    If you want to make a special dropdown list to you members, first of all you need to create the dropdown data type. You can do this by navigating to the Developer section and open the Data type-folder. In here you'll find all the available data types including the dropdown list. You can either edit the default Dropdown list data type, or create en new one, by right-clicking the data types-folder and choose 'Create'. If you just want to edit the default dropdown, click it to choose it.
    When you want to add values to the dropdown, you can type in one value at a time in the "Add value"-textbox, and then click the save-button. Then type in another value in the field, and click the save-button again.
    When you are done adding values, you can go to the Member-section, and add the dropdown to your membertype, just like you ad data types to a document type.
    Does it make sense?
    /Kim A
    Mar 30, 2010 @ 12:24
    Jonas
    Makes perfect sense! Just what I needed! Thanks.
    Mar 30, 2010 @ 12:29
    Kim Andersen
    Great Jonas - Glad to help.
    Remember to mark this question as solved if you feel that your question was answered good enough :)
    /Kim A
