In the developer section, you can open up the folder named "Data types". In here you can find all the data types that is available to you, and of course also the Richtext editor. If you click the Richtext editor, you can choose some different things about the editor. In example which buttons to show to the user, which styles should be available and so on. And also how big the editor should be. You can change the width and height of the editor here.
If you want to have several different sizes af your editor, yoou can create some "copy's" of the richtext editor. You can make this by right-clicking the data type-folder, and then choose "Create". This will create a new datatype with a naem that you choose. Lets say that you are going to make a new data type called "Frontpage Richtext Editor" and base this data type on the TinyMCE v3 wysiwyg-rendering control. Then you choose a different size to this editor. This means that you now have two richtext editors with different size.
Then you can choose the "Frontpage Richtext Editor" on you Frontpage document type, instead of the "Original" Richtext Editor.
This will result in two different sizes on two different document types.
resize wusiwyg editor in content
Hello everyone,
I might like to know whether it is possible to resize wusiwyg editor in content area.
I think you can set it to eg 233 x 300px to fit the box you have defined in the template?
Hi Jens
In the developer section, go to datatypes > richtext editor, then change the height and width here.
Dan
Hi Jens
/Kim A
Okay, I'm to slow again. As you can see I agree with Dan :)
/Kim A
But this will resize editor in all his conetent pages. What if he wants one size on editor in my home content and other size in help content page?
This is correct dogi.
/Kim A
