  • mike walls 8 posts 28 karma points
    Apr 02, 2010 @ 16:32
    mike walls
    iPhone Alt Package
    Umbraco 4.0.3/asp.net 3.5/Windows 2008 IIS 7 MS-SQL 2008
    Does anyone know if you have full control over the iPhone Alt package's look and feel? I'm wanting to use it as a starter if you can have full control of the look and feel. Thanks,
    -Mike
  • Sebastiaan Janssen 5060 posts 15522 karma points MVP admin hq
    Apr 05, 2010 @ 09:59
    Sebastiaan Janssen
    Sure, it's just an alternative template (masterpage) and you can do anything you want to it.
  • Jackon 5 posts 25 karma points
    Jan 04, 2012 @ 16:30
    Jackon
    Does anyone have an working example of this (iPhone Alt Page) working on Umbraco 4.7.x? We just upgraded - it was working before but it looks like its using the old XML schema and needs to be updated.
    Any anyone post the XSLT file which has been updated? Thanks in advance.
    Jan 04, 2012 @ 17:09
    Jan 04, 2012 @ 23:31
    Kim Andersen
    Hi Jackon
    Could you post the XSLT code that you need to update in here? Then we can all have a look at the code and maybe help you changng it to the new schema.
    /Kim A
