  • CodeMaster2008 151 posts 184 karma points
    Apr 02, 2010 @ 16:55
    CodeMaster2008
    Acessing properties of a document type
    I created a XSLT file using the "List Sub Pages From A Changeble Source" and it's working well.
    On the corresponding macro i have:
    <xsl:variable name="contentNode" select="umbraco.library:GetXmlNodeById($source)"/>
    <div id="features">
       <xsl:for-each select="$contentNode/node [string(data [@alias='umbracoNaviHide']) != '1']">
     <div>
         <xsl:value-of select="umbraco.library:RemoveFirstParagraphTag(data [@alias = 'SlideContent'])" disable-output-escaping="yes"/>
       </xsl:for-each>
    So, i already have the node that i need in the variable "contentNode", can i access the "generic properties" (the ones i created) from this variable?
    Something like:
    <xsl:value-of select="string(data [@alias = 'contentNode.MyProperty'])" />
    Apr 02, 2010 @ 17:34
    CodeMaster2008
    I got it:
    <xsl:value-of select="$contentNode/data[@alias = 'width']" />
    Apr 02, 2010 @ 20:47
    Kim Andersen
    Great that you solved your problem by your self :)
    A good idea is to make a textarea, and print out the source to see what you can access. In your case you could do something like this:
    <textarea>
    <xsl:copy-of select="$contentNode" />
    </textarea>
    This would give you the XML from $contentNode, and in here you can see which properties you can access.
    /Kim A
    Apr 02, 2010 @ 21:10
    CodeMaster2008
    It's good to know, thanks a lot.
