  • Christian Tarrild 23 posts 43 karma points
    Apr 05, 2010 @ 13:10
    Christian Tarrild
    "Member can edit" properties does not save
    I am running Umbraco v 4.0.3 (Assembly version: 1.0.3674.221). When I check the "Member can edit" or "Show on profile" checkboxes and save the membertype the membertype is saved but the tics in the checkboxes are gone. I have tried to manually edit the values in the database table "CMSMEMBERTYPE" but the boxes are not checked eventhough I changed the values from 0 to 1 in the databse. I have reproduced the error in another umbraco installation using umbraco v 4.0.2.1 (Assembly version: 1.0.3441.17657) where also the membership controls package is installed.
    How does "member can edit" and "show on profile" work?
    Regards Tarrild
    Apr 05, 2010 @ 13:11
    Christian Tarrild
    Forgot to add the the saving problem is both when using Chrome and IE8
    Tarrild
  • Dany Wu 81 posts 114 karma points
    Apr 15, 2010 @ 23:28
    Dany Wu
    I have only just started using the Membership functionality and noticed this too. Has nobody else had this problem?
  • skiltz 501 posts 701 karma points
    Apr 16, 2010 @ 01:21
    skiltz
    This is a known issue.  Make sure when you open the MemberType this is the first thing you do.
    Open MemberType - Click "Member Can Edit" -> Save.
    Apr 18, 2010 @ 13:50
    Christian Tarrild
    Hi Skiltz
    I have tried that already as I read it in another post, but that did not solve the problem.
    Then I looked in the source code and found an error in the MemberType.cs. I posted a fix on codeplex which has been accepted for umbraco 4.1, so lets hope that it is released soon. I  recompiled umbraco myself to obtain a corrected version of cms.dll which solved the problem, see www.tarrild.dk.
    Also see this post
    Regards Tarrild
