  • Dinovo 40 posts 59 karma points
    Apr 05, 2010 @ 20:12
    Dinovo
    Installed ultimate picker in V4 and now backend fails?
    Ultimate picker was installed on a V4 solution by error and then uninstalled shortly after it was installed - after uninstalling it, only the last item in the content tree on the left is shown (goes for all sections, developer, settings, content etc). Where should one look to find the error and fix it?
    Apr 05, 2010 @ 21:12
    Dinovo
    Problem found and fixed - turns out that the uninstall process removes the AjaxControlToolkit.dll completly, which caused the error.
    Apr 05, 2010 @ 21:18
    Hi Dinovo
    Which version of Umbraco are you running? Is it a 4.0.3? Maybe this is a bug that should be reported on codeplex?
