  • Bas Wensveen 54 posts 75 karma points
    Apr 05, 2010 @ 22:07
    Bas Wensveen
    True color picker
    Did anyone installed the True color picker on umbraco v 4.0.3 (Assembly version: 1.0.3680.15881). After installation I can't find the data type "True Color Picker".
    Kind regards,
    Bas
    Apr 05, 2010 @ 22:23
    Sebastiaan Janssen
    Hey Bas,
    I haven't used this package yet, but I bet you could just add a new datatype and from the "render control" dropdownlist choose the True Color Picker. After save, there might be more to configure.
    Apr 06, 2010 @ 16:20
    Bas Wensveen
    Hi Sebastiaan,
    I already did that. Tomorrow I will install it on a  clean umbraco installation. That might help :-)
    Regards
  • NM71 10 posts 30 karma points
    Aug 16, 2012 @ 16:14
    NM71
    I have installed the true color picker and works in document type.  But I don't see that in macro parameters.  I am adding .net usercontrols as macros and want to add the true color picker as property of the parameters.  Is this possible?
    Aug 16, 2012 @ 16:25
    Tom Fulton
    Unfortunately this won't work as a macro parameter, its designed as a datatype only.  You'd need to create your own macro parameter type (here's another), or perhaps use a textstring field for the color for now.
    -Tom
