  • Rachel Skuse 88 posts 118 karma points
    Apr 08, 2010 @ 10:41
    Rachel Skuse
    Using multiple checkboxes to create a string
    Is there a way to create a datatype that allows me to define a number of checkbox values and pass these values into a string?
    At the moment, my xslt queries a string and returns results based on the keywords found
    eg. Textstring has the values Modern, Dual Fuel, Electric, Stainless Steel, Silver
    but I would like these values to be available as checkboxes so that when a new item is added, the search criteria can be selected without having to type all the keyowrds into a textstring.
    I would then need these values to be saved as a string.
    Is this possible??
    Rachel
  • Samuele 9 posts 29 karma points
    Apr 09, 2010 @ 15:29
    Samuele
    I know that xslt are surely a great piece of work, although I always like to extend the cms with custom datatypes DOTNET made, pick your language (VB, C#) and write an ASCX, that should give you full control and you can achieve basically whatever you need. After that you'll just proceed integrating it as a macro. i hope this'll help you out
