  • tarekahf 215 posts 153 karma points
    Apr 10, 2010 @ 09:32
    tarekahf
    ObjectDataSource Configuration Wizard Does not work with Umbraco DLL Reference.
    I want to report a small issue.
    I am using VS2005 and Umbraco 4.03.
    I created Web Application Project, and enabled using Ajaxtoolkit for VS2005. All work fine.
    I created ObjectDataSource and CslaDataSource, and I am able to using the Configuratin Wizard to link the DataSource to a Class Library.
    See this snapshot: http://bit.ly/cfAchW
    I added a reference to Umbraco DLL and the DataSource Config. Wizard is returning Empty List, after I build the Web Application Poject
    See this snapshot: http://bit.ly/9WqCKa
    When I remove the reference to Umbraco DLL, and rebuild the Web Application Project, it it will work fine. The same behaviour applies for both CslaDataSource and ObjectDataSource.
    Pls tell me where is the best place to report this.
    Tarek.
