  • Erik Ernst 70 posts 90 karma points
    Apr 13, 2010 @ 13:42
    Erik Ernst
    Clickable World and Europe map for Umbraco?
    I'm looking for a script on similar to be able to make a clickable World and Europe map for Umbraco?
    I've looked a the ImageMap plugin, but it doesn't seem to be able to support what I want, which is when I hover the mouse over a country, then the country should be highlighted and show the name of the office.
    I have seen this on many sites, but I'm not really sure how to do it.
  • Petr Snobelt 923 posts 1535 karma points
    Apr 13, 2010 @ 16:24
    Petr Snobelt
    I use something like this. Hope it help you.
    http://www.svennerberg.com/2008/09/imagemap-rollover/
    Petr
    Apr 28, 2010 @ 08:13
    Erik Ernst
    Thank you but this is only for Norway, Sweden and Finland...
    Apr 28, 2010 @ 08:36
    Petr Snobelt
    It's about principle, you can use your own maps.
  • Fergus Davidson 309 posts 588 karma points
    Apr 28, 2010 @ 11:06
    Fergus Davidson
    i have recently used a flash-only map from:
    http://www.fla-shop.com
    they have lots of options at various prices, all xml fed, so easy to incorporate into umbraco.
    there is also an excellent tutorial on a non-flash version here:
    http://www.newmediacampaigns.com/page/a-jquery-plugin-for-zoomable-interactive-maps
  • wolulcmit 357 posts 693 karma points
    Apr 28, 2010 @ 11:45
    wolulcmit
    you can do some pretty cool things with maps using Raphaƫl (a vector graphic javascript library) http://raphaeljs.com/ it even has support for ie6. There's a map example on one of the demos.
