  • Sander van de Pas 74 posts 147 karma points
    Apr 15, 2010 @ 16:00
    Sander van de Pas
    ZIP Upload problem
    I have a site with Umbraco 4.0.2.1 installed on it and I’ve installed the ZIP Upload package.
    When I want to upload a zip, with only pdf files (no folders), it gets the following error:
    Server Error in ‘/’ Application.
    Wrong Local header signature: 0×21726152
    Exception Details: ICSharpCode.SharpZipLib.Zip.ZipException: Wrong Local header signature: 0×21726152
    Source Error:
    Stack Trace:
    [ZipException: Wrong Local header signature: 0×21726152]
    ICSharpCode.SharpZipLib.Zip.ZipInputStream.GetNextEntry() 1166
    Nibble.Umb.ZipUpload.zipupload.Button1_Click(Object sender, EventArgs e) 7011
    System.Web.UI.WebControls.Button.OnClick(EventArgs e) 111
    System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) 110
    System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) 10
    System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) 13
    System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) 36
    System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) 1565
    Do you have any idea why it happens?
    Thanx,
    Sander
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Apr 22, 2010 @ 13:44
    Jeroen Breuer
    It's about the ZIP upload created by Tim Geyssens: http://www.nibble.be/?p=55. Doesn't anybody know how to solve this problem?
  • Stefan Kip 1614 posts 4131 karma points c-trib
    Apr 22, 2010 @ 13:46
    Stefan Kip
    I guess the zip file is invalid.
    Can you test with a clean (self created) zip file (with one text file or similar)?
    Apr 22, 2010 @ 14:16
    Sander van de Pas
    I think the ZIP file wasn't correct. Tried it with a new created zip and then it worked!
    Thanx.
