  • phenryll 28 posts 53 karma points
    Apr 15, 2010 @ 21:31
    phenryll
    Adding a SyntaxHighlighter for snippet code
    I am a .NET developer and I was wondering if Umbraco provided a way to highlight snippet code in a way that SyntaxHighlighter offers.
    For a screenshot: http://alexgorbatchev.com/wiki/SyntaxHighlighter:Brushes:CSharp
    Thanks in advance.
    R.
    Apr 15, 2010 @ 23:05
    Morten Bock
    Depending on your needs, you might be find this package useful:
    http://our.umbraco.org/projects/prettify4umbraco
    If not, then it is pretty easy to implement SyntaxHighlighter on your website.
    Where do you want the highlighting to happen?
    Apr 15, 2010 @ 23:06
    Dirk De Grave
    Guess he wants it in de backend, in which case he'll have to use v4.1 as it's supported oob from that version onwards.
    /Dirk
    Apr 16, 2010 @ 10:40
    phenryll
    Thanks guys. The Prettify4Umbraco seems to be what I am looking for.
    The typical scenario is the following: I create a page, I want to insert a snippet code that is highlighted. As an admin, I insert my code and it must be highlighted on the front-end at least.
    Dirk, what does oob stand for please?
    Apr 16, 2010 @ 11:10
    Dirk De Grave
    oob = out of the box
    Apr 16, 2010 @ 13:28
    phenryll
    Thanks a lot guys.
    R.
