  • RoelAlblas 50 posts 61 karma points
    Apr 17, 2010 @ 11:05
    RoelAlblas
    Images dissapear after save or publish
    When I load certain images into a rich text editor they shows up just right. But when I publish or save I get the famous red cross. I read one post that says that he fixed it by deleting the folders and create them again. This is not a solution for me. (May be it will be?)
    Any suggestions?
    Roel
    Apr 17, 2010 @ 16:26
    Kim Andersen
    Does this occour in all browsers or just in some/one of them? And could you check if the path to the image is correct, or contains any special characters or spaces.
    /Kim A
    Apr 18, 2010 @ 17:04
    RoelAlblas
    Hi Kim,
    Special characters pffff ...
    Thanks!
    Roel
