  • Mikael Mørup 297 posts 326 karma points
    Apr 19, 2010 @ 13:19
    Mikael Mørup
    Iframe problem
    I have a macro that inserts an Iframe into a rich text editor field.
    After saving the node, Tiny MCE messes with the HTML, so the closing </iframe> tag that my macro inserts is replaced with the /> ending of the Iframe tag.
    This messes up the rendering of my template, is there anything i can do to prevent this ?
    Mikael
  • Søren Eriksen-Aagreen 29 posts 76 karma points
    Apr 19, 2010 @ 13:49
    If your macro is a xslt macro - Could this have something to do with your xsl output method ?
    Is it set to <xsl:output method="html" omit-xml-declaration="yes"/> or <xsl:output method="xml" omit-xml-declaration="yes"/> ?
    n
    Apr 19, 2010 @ 20:35
    Mikael Mørup
    Its:
    Should it be HTML (hmm i guess so) ??
    Apr 19, 2010 @ 20:39
    Mikael Mørup
    I should.
    Apr 22, 2010 @ 11:08
    Great! :)
