Is there anyway to have a stand alone folder/page inside umbraco?
Scott
Yup, just configure web.config to ignore your files/folders
<add key="umbracoReservedUrls" value=",/config/splashes/booting.aspx,/config/splashes/noNodes.aspx," /> <add key="umbracoReservedPaths" value=",/umbraco,/install" />
Hope this helps.
Regards,
/Dirk
ignore = ignore by umbraco!
What do you mean Dirk?
Scott, do you need to have a "folder" inside the Content-tree, or what do you mean excatly? Is it just a physical folder in the file-system like Dirk talks about, or what do you need?
/Kim A
Scott
Hope this helps.
Regards,
/Dirk
/Kim A
