  • Chloe Jones 1 post 21 karma points
    Apr 23, 2010 @ 12:55
    Chloe Jones
    dynamic css background for div element
    hi, just wondering if there was a way of dynamically setting a background image for a div depending on the page you are on. there's no need to create a seperate template as the structure's exactly the same.
    any help appreciated.
    Apr 23, 2010 @ 13:06
    Lee Kelleher
    Hi Chloe, welcome to the Umbraco forum.
    Take a look at the Dynamic Body Tag macro, you can apply CSS rules (for background-images) accordingly.
    http://our.umbraco.org/projects/dynamic-body-tag
    There are many other ways of doing what you want, but this is a good starting point.
    Let us know how you get on.
    Cheers, Lee.
  • bob baty-barr 1180 posts 1294 karma points MVP
    Apr 25, 2010 @ 20:35
    bob baty-barr
    i have done this on a few project... basically, use a media picker on the node.. for background image... and in your template, insert a macro that renders the div according... or you could use some inline xslt too... :)
    on this site... http://test.mtturl.com i use some jquery to scale the backgound image...
    here is my xslt macro...
    <xsl:template match="/">
    <!-- start writing XSLT -->
    <xsl:if test="$currentPage/data[@alias='bgIMG'] != ''">
      <xsl:variable name="imageNode" select="$currentPage/data[@alias='bgIMG']"/>
      <xsl:variable name="imageData" select="umbraco.library:GetMedia($imageNode,'false')/data[@alias='umbracoFile']"/>
      <img src="{$imageData}" />
    </xsl:if>
    </xsl:template>
    and my template has this div and macro...
    <div id="supersize">
            <umbraco:Macro Alias="RenderBGimg" runat="server"></umbraco:Macro>
    and using this jquery to do the supersizing :)
    /* <![CDATA[ */
    (function($){
      //center things
      $.fn.center = function () {
        this.css("position","absolute");
        this.css("top", ( $(window).height() - this.height() ) / 2+$(window).scrollTop() + "px");
        this.css("left", ( $(window).width() - this.width() ) / 2+$(window).scrollLeft() + "px");
        return this;
      //Resize image on ready or resize
      $.fn.supersize = function() {
        //Invoke the resizenow() function on document ready
        $(document).ready(function() {
          $('#supersize').resizenow();
        //Invoke the resizenow() function on browser resize
        $(window).bind("resize", function() {
            $("#container").center();
      //Adjust image size
      $.fn.resizenow = function() {
        //Define starting width and height values for the original image
        var startwidth = 1440;
        var startheight = 956;
        //Define image ratio
        var ratio = startheight/startwidth;
        //Gather browser dimensions
        var browserwidth = $(window).width();
        var browserheight = $(window).height();
        //Resize image to proper ratio
        if ((browserheight/browserwidth) > ratio) {
            $(this).height(browserheight);
            $(this).width(browserheight / ratio);
            $(this).children().height(browserheight);
            $(this).children().width(browserheight / ratio);
        } else {
            $(this).width(browserwidth);
            $(this).height(browserwidth * ratio);
            $(this).children().width(browserwidth);
            $(this).children().height(browserwidth * ratio);
        //Make sure the image stays center in the window
        $(this).children().css('left', (browserwidth - $(this).width())/2);
        $(this).children().css('top', (browserheight - $(this).height())/2);
    })(jQuery);
    $(document).ready(function(){
      $("div#supersize").supersize();
