  • Dan Evans 631 posts 1018 karma points
    Apr 28, 2010 @ 10:32
    Dan Evans
    public access stops working after migration from II6 to IIS7
    I have just moved an Umbraco 4.0.2.1 site from WIndows Server 2003 to Windows Server 2008 running in Integrated Pipeline mode. I have upgraded the web.config as instructed.
    Users can login to the Umbraco backend fine however members cannot login. If a correct password is entered the login page just refreshes cak to the login form. If an incorrect password is entered then the user is told it is incorrect.
    This leads me to believe that the authentication is working fine but for some reason the login session is not being set.
    Any ideas?
    Dan
    Apr 28, 2010 @ 10:58
    Dan Evans
    I've found the answer here:
    http://our.umbraco.org/forum/developers/api-questions/4207-Member-login-won%27t-work
    Perhaps these instructions should be included in the general instructions on migrating to Integrated Pipeline Mode?
