Is there an easy was to mass publish items across an entire site in Umbraco.? I am looking into having a parent site with many children sites, and being able to make changes to the parent and it affecting all the children would be ideal. Is there a module for anything like this, or would it have to be personally created to my needs? Thanks.
This can be achieved by organising your content correctly. You would create a top level node for each website and a separate structure for the shared content, for example:
- Site 1 - Site 2 - Shared Content -- Shared Item 1 -- Shared Item 2
Therefore you don't need to publish to multiple sites as the sites are pulling from the shared content anyway.
One-Click push to multiple sites
Isaac
Hi Isaac,
- Site 1
- Site 2
- Shared Content
-- Shared Item 1
-- Shared Item 2
Chris,
Can you go into a little more detail on how I would implement this? THanks.
See my comments on your other thread,
http://our.umbraco.org/forum/using/ui-questions/8842-One-Click-push-to-multiple-sites?p=0#comment32394
-Chris
